Silver flakes in coolant
Old 03-23-2024, 02:49 PM
lordys2000's Avatar
Default Silver flakes in coolant
Hi all, it's been a while since I posted here for anything.
Been carrying out the annual service and it was time for a coolant change, however I noticed that there are silver flakes in the coolant - see pictures below. There seem to be some in the drained stuff, but its more noticable in the freshly circulated new coolant.
I have done a search and there are some indications it may be a water pump failing, but by many accounts that is very rare in these cars. Another possibility is that if there was an air pocked and its been sat a while, there could be some corrosion, hence the flakes. The car has been sat for a few months whilst I've been working on the rear subframe and suspension (around 4 months I think), so could this be the cause?
I'd welcome any thoughts, plus any guidance about how urgent an issue this is.
Cheers
Old 03-23-2024, 02:50 PM
lordys2000's Avatar
To add, the car is a MY2000 and has done around 77000 miles
Old 03-24-2024, 02:02 PM
Nottm_S2's Avatar
That's quite alarming
Are they magnetic?
Old 03-24-2024, 02:18 PM
Jayc87's Avatar
Take its a oem rad? Like above get a magnet and test those particles.
Old 03-24-2024, 02:36 PM
noodels's Avatar
Maybe has water pump bearing issue
Old 03-25-2024, 02:15 AM
Jayc87's Avatar
Very possible. Could be premature bearing failure. Checking if the particle are magnetic will help diagnose.
Old 03-25-2024, 12:36 PM
lordys2000's Avatar
I've checked and the particles don't seem to be magnetic. I took another look at the old coolant, and its difficult to see if there are any particles in it (it went in a less than clean bucket, so there is a bit of dirt, but not lots of specks). Opening the cap of the radiator, its immediately clear there are plenty of particles there.
I took off the serpentine belt to check the water pump - the pulley turns freely, and there doesn't seem to be any play to indicate a bearing issue.
The particles themselves are not hard flakes, more like dust, and can be rubbed away when I got some coolant on my finger.
So latest is:
- Particles not magnetic
- Particles are very fine like dust
- Very few particles in old fluid
- No play in water pump pulley
Would this fit with the air pocket causing corrosion theory, or are we looking at worse like head gasket issues?
Old 03-25-2024, 01:49 PM
Nottm_S2's Avatar
Well if not magnetic they are probably aluminium as they are also quite bright
I looked in mine, could not get a good pic in the reservoir but nothing in there glistening.
Do you have an ally rad or anything?
Old 03-25-2024, 02:11 PM
lordys2000's Avatar
Just the standard original oem radiator.
Perhaps what I'll do is get a new water pump, and flush the system a couple of times with deionised water and refill with coolant again.
Reading around it could be corrosion, maybe because the car wasnt used for a bit, but it's sat for several years before without any issue like this.
Old 03-26-2024, 11:22 AM
Jayc87's Avatar
Glad its not looking engine related.
sometimes an old rad breaks down inside and you get some particles..
Id recomend a good flush through. And check again soon. Does it loose any coolant?
Quick Reply: Silver flakes in coolant
