soft rubber seals treatment
Old 12-12-2017, 11:11 AM
john walker's Avatar
Default soft rubber seals treatment
I every one got a bit of spare time over xmas
looking at just making car a bit more perfect a bit anal really
but if I ever sell her its been done properly to a new owner
opened the boot and the soft seal that is on the bottom of the boot lid and any others seals like this can you coat it with a silicon type spray to keep it really soft to make it last and not go hard thanks john
Old 12-12-2017, 12:34 PM
Little Bob's Avatar
Honda Shin-Etsu grease is what you need John:
https://h-tune.co.uk/genuine-honda-s...SABEgLMMPD_BwE
Old 12-12-2017, 01:22 PM
BuggyofMildDiscomfort's Avatar
Almost any silicone oil/paste will work. I just get a 250ml bottle of 100-200cst shock fluid from the local RC model shops for 5-10 quid.
Old 12-12-2017, 01:51 PM
richmc's Avatar
Shin-Etsu is high in lanolin (oil from sheep's wool), softening and absorbable unlike high silicone content ones that can be harsh, divers lube is a good alternative if you can't get the recommended lube.
Be careful some lubes can attack rubber, Vaseline for instance is not recommended except for flexible plastic seals.
Old 12-12-2017, 04:23 PM
The base oil is silicone though. If it's lanolin blended that's cheap too, although it stinks to high heaven
Old 12-12-2017, 11:57 PM
Little Bob's Avatar
I'll take the Shin-Etsu, I know it works.
I'd be guessing if I tried to buy something cheaper for the sake of saving a small amount of cash.
Old 12-13-2017, 01:34 AM
UK Moderator
lovegroova's Avatar
I've had the same tube of shin-etsu for the last 12 years, overall, the cost is not excessive!
Old 12-13-2017, 02:29 AM
Nick Graves's Avatar
An aresole of Holt's silicone & rubber spray is my goto.
Seems to be very quickly-absorbed, so you'll need to go over it a couple of times.
I use a sock puppet, to apply it neatly.
Since only one of the cars has window frames, I get through quite a bit of it, over a decade...
Old 12-13-2017, 02:37 AM
Little Bob's Avatar
Sock puppet?
Old 12-14-2017, 11:00 AM
UK Paul's Avatar
Originally Posted by Little Bob
Sock puppet?
Think about it....
I thought an arsehole comment was funnier.....
Quick Reply: soft rubber seals treatment
