Soft Top Control Module
Old Jun 12, 2012 | 04:29 AM
Floppy's Avatar
Default Soft Top Control Module
Just a quick couple of questions...does anyone know where the soft top control module is located and how easy it is to get to and get out?
Also at a guess once this comes out I can't operate the top unless its manually...and does the soft top need to be up or down if I plan on removing it with the frame intact so I can just bolt it straight onto my new car?
Thanks,
Alex
Old Jun 12, 2012 | 06:55 AM
N5THM's Avatar
Its located behind the passenger footwell panel, pop this off, needs a good yank sometimes.
it looks like this:
http://i.ebayimg.com/00/s/NjY3WDEwMDE=/$(KGrHqVHJEoE917SHz7oBPoLucEY-w~~60_1.JPG?set_id=8800005007
One 12mm screw holding it on.
Old Jun 12, 2012 | 01:28 PM
Floppy's Avatar
That's brilliant, thanks for your help
Old Jun 12, 2012 | 03:28 PM
JMRGV's Avatar
Agreed; most helpful!
Old Jun 13, 2012 | 01:16 PM
Floppy's Avatar
Found it
http://www.flickr.com/photos/alex-collins/7369790914/http://www.flickr.com/photos/alex-collins/7369790914/ by http://www.flickr.com/people/alex-collins/, on Flickr
Old Jun 18, 2012 | 03:17 AM
JMRGV's Avatar
Quick last question if I may;
I am going to be swapping my knackered soft top control module over with the above (Alex was kindly retrieving his for me, hence the above thread).
As I am entirely inept in such matters, could I ask for your guidance in swapping the modules over please?
1. The panel I understand just pulls off (carefully!). Presumably I just start with teh bottom attachment points and gently yank them off, workinf my way up.
2. Can I just unplug the old module and plug in the new one (plus bolt out/in of course)?
3. Should I (not?) disconnect the battery first? Presumably ignition off. Someone elsewhere said they blew their module when fiddling with headunit electrics so concerned not to cause myself any more problems!
Cheers all!
jm
mrmumbels
Nov 26, 2005 06:53 AM
