Spark Plug Change
Old Apr 13, 2015 | 06:26 AM
AndyNFRS2k's Avatar
Default Spark Plug Change
Hi Everyone
Coming up to my 81k mile service, and I was just about to buy some spark plugs, but noticed on the Honda service schedule while doing a search on here for spark plugs and what is actually due on an 81k service, that they're only due on the 6 year/54k service?
Is this right?
With all my other cars I've changed the plugs every 3 years regardless of mileage (mines only done 42k, and only 5k since they were last changed at the 54k service), so is it advisable to change them? Or is it just not necessary?
I'll be happy either way, as I'm quite happy to change them, but will save me a few pennies if it's not required.
Cheers!
Andy
Old Apr 13, 2015 | 06:31 AM
Trunkz's Avatar
Reason being is that the S2000 utilizes platinum plugs which dont require frequent changes hence the longer gap However take out the plugs and inspect them to see if they require being changed. (You never know if it was done at the correct service interval )
surfer_crx's Avatar
Standard plugs last for aaaages.
I would check them and make a judgement call, failing that spend the £30 odd and just stick a new set in there for piece of mind, they come pregapped and shouldn't be adjusted so it really is easy.
Old Apr 13, 2015 | 06:40 AM
AndyNFRS2k's Avatar
Ah right, now I understand why - thanks guys
They were changed at 54k so will get them checked, but I'm sure they'll be fine.
Old Apr 13, 2015 | 08:13 AM
JoeperkinS's Avatar
As said earlier change them, takes 20 mins and £35 is worth any issues
Old Apr 13, 2015 | 09:01 AM
dwb993's Avatar
^Agred. Make sure to torque them properly.
Old Apr 13, 2015 | 09:56 AM
richmc's Avatar
And if they do look like they need changing, DON'T BUY DENSO.
Old Apr 13, 2015 | 10:08 AM
S2KIP's Avatar
Why not Denso? I was going to use NGK anyway as they're cheaper.
Old Apr 13, 2015 | 10:09 AM
JoeperkinS's Avatar
They're awful. Ngk are a far superior plug, Denso make good parts but ngk are from my experience with other cars also the best plug.
Old Apr 13, 2015 | 01:08 PM
richmc's Avatar
Do a search and you'll find out why.
blue monster
Nov 17, 2011 09:26 AM
p800bry
May 16, 2011 09:00 AM
yhaneef
Apr 19, 2009 01:13 PM
JimmyB
Jul 16, 2005 09:32 AM
S2000AD
Apr 5, 2004 10:07 PM
