Spoon Rad cap
Unless you'll be running the car a load hotter, I'd not bother (FI, higher revs or higher CR).
Things like the thermostat / rad cap are things I'd add once you are having issues. They are ways of resolving issues.
I needed to swap mine, as the stock rad cap doesn't fit on the Koyo rad (different design). I later found out the Koyo is the same design as my old Toyota, I could have used a spare one I had. D'oh.
AJ - I've fitted the J's Thermostat, rad switch and Rad cap to mine in anticipation of fitting my gears which does actually mean that I will be running at slightly higher revs.
It may be overkill though
Originally Posted by eSeM,Dec 18 2007, 03:34 PM
IIRC Mugen recommend that you upgrade the rad cap, oil cap and rad switch if you are using a Mugen ECU.
I suspect that would be the same for other ECUs
Guess its working better in terms of ECU settings with a cooler engine.
I can see why the cooling mods are needed for track days, and that's what the Mugen ECU is intended for.
Originally Posted by Ajs_s2k,Dec 18 2007, 01:14 PM
You have little faith mark
, this does not mean i want to buy the item I'm purely interested by the differences/benefits if any such modification would bring and the pro's and con's.
, this does not mean i want to buy the item I'm purely interested by the differences/benefits if any such modification would bring and the pro's and con's.It just read like you were thinking the new ECU was going to make the car work that much harder, that a new rad cap was needed! I still think you may be a bit dissapointed by the results from the ECU, so i'd do that first and see how you get on.
But again, I think for hard driving and trackdays its a good thing.
Originally Posted by MB,Dec 18 2007, 04:26 PM
I'd say overkill
Originally Posted by thenationsguitar,Dec 18 2007, 04:29 PM
I've just bought one!! well with a S/C thought it was better to cover everything, would have thought i'd be putting a lot of heat into the car with this lot :#
You'd laugh at the size of the stocker ..
