Squeaky clutch?!?!
Hey everyone, ive noticed my clutch has started to squeak now after about a months ownership, ive had the same problem on a previous Honda, anyone have any ideas what it could be, its not really annoying but would like to fix it, if possible, thanks
https://www.s2ki.com/s2000/topic/370...-clutch-pedal/
Also spray some grease at the end of the pedal on the pedal floor
could be a few things. if its coming from inside the car the n you probably need to lube the pedal arms/hinge points. if its coming from under the car oyu probably need to lube the slave cylinder/clutch fork, or also the clutch fork to throw out bearing arms. i suggest using honda hi temp urea grease for this.
shiftmeister
Sep 13, 2003 06:56 PM
