Steering / Handling feels loose
when I say understeer, the front or steering seems to feel very light if you try to increase speed through the corner. If you lift off in the corner, it feels like it pitches forward and the rear goes light.
i honestly can't say about left and right turns. Never thought to compare.. certainly noticed on left turns as per the example sliproad given earlier.
Didnt know we had passive rear steering
from what people have said a recheck on the geo deffinately seems the first thing to check, then go from there.
No, it's not the diff. It's the rear suspension geometry that is set up to toe a little further in under load (on throttle stability), but has the opposite effect of toeing a little further out under less load (off throttle nervousness). It's exactly what is being described above.
Some like it, generally confident drivers, but it can catch some drivers unawares. And some (like me) just don't like it being THAT adjustable on the throttle. Hardrace (or similar) rear toe arms solve it, as they bring the toe arms more parallel with the wishbones and pretty much eliminate the passive RWS.
Can wear on some parts exaggerate this effect?
would this be a specific bush then, or is the wear on the toe arm? As I say all the bottom arm bushes have been changed?
My guess would be that it's not the major contributor, but the rear toe arms do have rubber bushes in which could be worn, but you'd notice their deflection more during bumps (bump steer, rather than throttle steer which is due to the angle of the control arm inducing toe in/out).
