Steering Wheel
At 6'6", I don't find the S cramped, but I do find the wheel is too big. I have to 'heel and toe' with the side of my foot. I also find very tight corners an issue as I have to let go of the wheel and shuffle it round, much like you had to when learning to drive, which isn't ideal from a car control point of view.
So my question is, what steering wheels out there are suitable for the S, but are smaller? Are the later model wheels smaller in diameter? I really like the look and feel of my OEM one, but it's just too damn big! I'd like to retain the airbag if possible as well.
Originally Posted by chrisr111,Aug 16 2009, 07:22 PM
There are plenty of non-airbag wheels available which fit provided the correct hub is used.
Not the same as the S2000, granted, but I've just put a significantly smaller steering wheel in my land rover. It took several weeks to get the hang of it, as it's changed the handling dramatically.
I went for a 12" Mountney steering wheel (from the original 16" ish LR one), for exactly the reasons that you've described - more leg room and better ability to get your hands around the wheel at funny angles. The other thing that I found is that with the boss plus the dished wheel, the rim ended up a lot further away from the dashboard.
I'd be happy to let you borrow the wheel and boss from the landy, for a trial fit in the S2000. The splines will be wrong, so no good for a trial drive, but a dry run would work.
Should you end up removing the airbag permenantly, I read in a "removing the passenger seat airbag" thread that you can fit a resistor in lieu of the bag and retain the use of the system as a whole.
Originally Posted by loftust,Aug 16 2009, 09:12 PM
Can you recommend any Chris? I'm not keen on those with bells/whistles/buttons on them. Something sturdy, attractive and relatively small would fit the bill.
Chris.
