STU_C: TURBO Project (UPDATED: 16/05/2010)
#33
Hi All,
Update! Parts have all arrived this week and build almost complete!!
AEM Fuel Rail & 550cc Injectors (The First One Ever Bought and Fitted In the UK)
Injectors, Fittings and AEM Fuel Regulator Fitted to Fuel Rail
Intake Manifold Gasket
Intake Manifold Gasket fitted
AEM Fuel Rail & Polished Manifold Fitted
HKS Blow Off Valve Fitted
New GReddy Single Exit Exhaust
New GReddy Exhaust Fitted
Cusco Rear Brace Fitted
BC-Racing Coilovers To Be Fitted
BC-Racing Coilovers Fitted
BC-Racing Coilovers With Adjustable Damping
GReddy Oil Cooler Kit To Be Fitted
Steel Braided Oil Lines
GReddy Oil Cooler Fitted
GReddy Oil Catch Can to be fitted
Engine Bay So Far.......
I like the pale blue and red hoses together so be keeping these like it, also have a front strut brace but due to the turbo inlet pipes the strut brace wont fit so ill look into this part
#34
STU C that looks amazing. Just a word of caution. A few years back I had a Celica gt4 turbo with lots of mods, it to had a remote oil filter with very similar oil pipes to your S2000.
They to were, shall I say in avery warm part of the engine bay!!!!!Just like your instillation,I had heat shrouding pipes covering the oil pipes but eventually the heat got the better of the alloy joints, the ensuing failure pumped oil over the hot turbo / manifold.Only black smoke exiting out of the air intake for the intercooler on the bonnet alerted me to the problem!
Luckily it did not catch fire or lose enough oil to seize the engine.
I ended up using steel couplings with braded hoses + heat shrouding over the pipes to solve the problem.
Good luck with the rest of the build
#36
Originally Posted by stu_c,May 16 2010, 07:54 AM
the oil pipes are braded hoses mate
#37
I had some issues with the ally fittings due to heat so changed all mine to steel they don't look as colourfull as the ally ones but sure are 10x better for not working loose and resistance to heat
