A stuck front caliper
I'm planning on using an M10 bolt and a couple of washers to seal up the banjos while I've got mine off - not sure if it's doable but I'm going to give it a go. Also putting a plastic bag over the fluid reservoir filler hole and screwing the lid back on will reduce amount of fluid lost too.
1 Post
Someone in the same thread also suggested those roll up ear plugs which I've actually got too.
I'll get lots of before and afters!
no fluid loss and no air in the system
Not sure I'd clamp braided hoses, but I've never tried
Sorry state the obvious - but BDt85, you don't say if you have checked that the pistons are seized, it could just be the slider pins that are seized. I'm not sure you can tell the difference without taking the pads out and trying to push the piston back into the calliper a few times. £139 is a brilliant price for a refurb if you need one though.
1 Post
The pistons will definitely move as I only did a pad change 70 miles ago and obviously had to push them back. They might be a bit sticky or as you said it might just be the pins.
For £140 quid though on a 12 year old car with 81k, I'll just pay up and let the pros refurb completely and finish them.
