Things to ask the guys at the garage to do...
Doesn't seem a lot for the money TBH - all I can see there that's really worthwhile is;
8. Drain and refill engine oil
9. Replace engine oil filter and sump washer
36. Replace air filter
37. Replace pollen filter
38. Replace brake fluid
For what you (don't) get with that service, I'd seriously consider a trip round the M25 to visit TGM with your original list (might be worth getting a coolant change too) - I think you can drop off and pick up on Saturdays from there if it helps organise your life.
http://www.tgmsport.co.uk/
I did think the list was a bit rubbish for the money. It'd take a bit more planning/organising for me to bgger off to Hampshire (if that's the right TMG?). So maybe next time I guess.
Would TGM have a 'service' list that they could share as well do you think?
Yes, that TGM. However, you do have Dixon (http://www.dmsracingltd.co.uk/) much more local to you but I have no personal experience so can't testify either way.
Sorry I am not in my office all the time so best way is via email to get me - info@dmsracingltd.co.uk
Thanks
Dixon
Thanks
Dixon
Thanks
Dixon
Thanks
Dixon
am now (via email) in the process of arranging work to be done at DMS.
Update.
I'm booked into Dixons today for the following:
Engine oil
Gearbox oil
Diff oil
Oil filters
Brake oil
Clutch oil
Spark plugs
Coolant
Grease gear lever and check for boot leak and rear arch too
Check all ball joint and overall condition of the cars, brake disk/pad, Tyres, seized bushes...etc
Could anyone tell me the benefit of the valve clearance work? That would be extra so I'd like to know the benefit if possible.
Thanks for all your input
Engine oil
Gearbox oil
Diff oil
Oil filters
Brake oil
Clutch oil
Spark plugs
Coolant
