Throttle Body Gasket
Evening all,
After reading a thread where cleaning the throttle body resolved the whistle associated with the K&N I'm going to give it a go. Will order a gasket, but do I need sealant or not? If so, I'll get this at the same time as the carb cleaner.
Anything else I should clean or replace whilst in there?
Graeme
Graeme
Anyone else used sealant? I can hear air being sucked in and car isn't running 100% smooth. If I spray carb cleaner around the top of the throttle body seal the revs pick and up die, so definitely not a good seal. I'll try refitting, but maybe also try gasket sealant????
F**K... just snapped one of the studs as I put it back together and it was still leaking at the top.... tried too hard
Will start a new thread
Does this look like the right gasket? Certainly fit in all the right places.
BOARDPARADISE
Jul 18, 2017 04:54 AM
RCR S2
Mar 30, 2005 09:30 AM
