Timing chain replacement
Hi,
I've just noticed a slight metallic rattle coming from (what appears to be) the front of the engine. It's not the usual TCT rattle, and given that I'm now approaching 100k I'm wondering if it's time to get the timing chain replaced?
If so, are there other ancillaries that need replacing at the same time?
I would be tempted to remove the Auxilary belt off and check the various pulley bearings for play or noise. Its alot easier to fix one of those bearings then to change the chain which will cost you a small fortune.
If you do decide to go ahead, you may find this post/ rest of the thread useful:
https://www.s2ki.com/s2000/topic/865...t__p__20614912
Its only very slight at the moment, you can only hear it at idle with your head in the engine bay. I hope its not the timing chain yet as I know its not a cheap job. I'll have another look tomorrow and maybe get a video.
If your about call down Sat, there'll be a few down to have a listen
. To be honest I was gonna give you a shout about getting this prop greased over the next few weeks or when possible
