Track Pad Longevity
Track Pad Longevity
I know there are a few track guys on here so was after some opinion on how long your pads last.
I started off using yellowstuff and when I got a little better at driving they weren't good enough, then I bought bluestuff as I needed new pads and was short of cash, they have lasted a lot longer but still only 4-5 track days.
Is this normal? How many trackdays should I be expecting out of a set of pads, something to bear in mind is I drive Blyton circuit a lot and that's very heavy on brakes and tyres.
I've only done a few but they are generally hard on both tyres and pads. even if you don't do many laps your car gets covered in rubber debris (especially noticeable if wet) and wheels caked
I think 4-5 is probably good, especially if you're doing a fair few laps
Also found yellowstuff pretty poop for life, I killed a brand new set in one and a half trackdays +1000 road miles.
I'm currently using a set of Carbone Lorraine RC5+ and they are at 3 trackdays +4000 road miles and have about 1/3 life left in them.
If you haven't already perhaps a cooling kit may help
i had my first set of carbone lorraine's fitted a couple of years ago and couldnt believe the upgrade from everything else ive tried. they lasted around 7-8 track days roughly (on blank discs). not ridiculously expensive around £270 for all corners covered. cannot reccommend them enough.
