Tramlining
I've just put my set of F1s on now the weather's deteriorating and they're distinctly less able to deal with uneven road surfaces than the Bridgestones they replaced and tramline quite markedly on our (not so smooth) roads.
Does anyone have any simple theories or ideas on how to reduce this? Maybe I'll start playing around with tyre pressures to see what difference that makes. I was running the S02s at 34 all round which certainly worked well, and have 34 on the F1s at the moment.
Any time in the past I have had tramlining this has fixed it.
You may find that the F1's which are certainly a softer sidewall may have a larger or smaller footprint than the S02.
In 225 format its likely to be smaller on the tire tread width and rradius , 245 x 45 seems to be the replacement rear size and is most likely to be a wider tread width than the So2s
Its possible that the softer tire follows the road more , the stock S02's are Very stiff. Or it could be that the F1's different contact patch again follows the ruts more...
or none of the above
Ive found that the alternatives to the S02's need careful consideration as even replacing like for like sizes different brands offer different size tire widths for the same size.
Speed Diam Width Weight Rating RRadius
SO2a 205/55/16 W 25 7.1 10.0Kg 140 A A
S03 205/55/16 W 24.9 7.6 10.9 Kg 220 AA A -0.4%
SO2a 225/50/16 W 24.8 8.5 11.3Kg 140 A A
S03 225/50/16 W 24.9 8.3 11.8 KG 220 AA A -0.4%
T1R 205/55/16 W 25.2 8.4 9.5kg 280 AA A 0.8%
T1R 245/45/16 W 24.96 9.8 9.8kg 280 AA A 0.6%
S03 245/45/16 W 24.6 9.1 11.8 KG 220 AA A -0.8%
Kelk
Apr 26, 2004 12:29 PM
juicy
Apr 19, 2004 10:58 PM
