two button remote
Old May 8, 2003 | 10:40 AM
njg2000's Avatar
Default two button remote
i have the two button honda remote, but the book does not tell me how to use its functions etc! like today i discovered it can open the boot! Does anyone have a full manual or instructions on how to use it properly?
Old May 8, 2003 | 12:00 PM
moff's Avatar
I have got the instructions, and theres not a lot to them.
To open the boot, unlock the car and after the indicators have flashed once press the unlock button again within 3 seconds, and the indicators will flash twice, this should open the boot, but it doesn't always work
When locking the car after the 5 flashes if you hit lock again the indicators will flash a further 3 times and the motion sensors inside the car will be disabled. If the top is down they should be disabled anyway.
The panic facility is operated by holding down the raised button for 3.5 seconds.
And thats about it!
Confusing or what!
Old May 8, 2003 | 01:30 PM
Thermo's Avatar
The boot release is very hit and miss. I think the three sec start a bit before the indicators go off as I have more success opening the boot if I press the button just as the indicators go off.
I did wonder if the remote batteries needed replacing as the manual suggest every 6months. I also found the motion sensors don't auto disable if the roof is down. Not sure if I have a fault.
The alarm will also re-arm if no doors are opened after x number of seconds of disarming the car.
After pressing the arming button the led will come on but the system motion sensors do not arm until 45sec later, led will then flash.
Once opening the car with the remote you have 30sec to start the engine before the immobiliser kicks in again led will come on, just press the diarm button again and press the red button .
Hope this helps
Old May 8, 2003 | 03:02 PM
astage's Avatar
Not sure if the link still works, but I did OCR the UK alarm manual and one of the guys on here - very sorry, name forgotton - made it available on the following site:
www.ireallywanna.com/s2000/honda-alarm.pdf
Let me know via PM if it is not there and I'll E-mail it to you.
Old May 8, 2003 | 03:07 PM
Chris Type R's Avatar
The link still works
Old May 8, 2003 | 04:32 PM
astage's Avatar
Thanks! I posted via a WDA (over a mobile phone link) so didn't want the shock of the bill in testing the link out!
To whoever it was that offered the hosting of the .PDF - very many thanks! Hope you don't take that wrong!
DaDoRonRon
Apr 19, 2008 03:08 PM
syvee
Oct 17, 2007 09:49 AM
JimUK
Oct 17, 2007 02:36 AM
Yannic
Dec 18, 2006 08:25 AM
9005rpm
Dec 19, 2003 10:31 AM
