View Poll Results: Please select tyres you've used on an S2000 and would recommend
Voters: 537. You may not vote on this poll
The Tyre Thread - Want to know about tyres? Then look here
#521
UK Moderator
#523
Interesting to note KG CLE comments on the Goodyear Eagle ASY 2 XL 17's. I had ordered 2 of these for the rear of my car (before KG's comments.were posted) on the basis of generally favourable comments, and issues getting hold of MZ's. Having had them fitted this morning and taken the car on a quick run, unfortunately my initial thoughts are exactly as described by KG. From being superbly balanced and inspiring confidence before, the car now feels 'edgy' and unbalanced. When you turn into a bend it feels as though the back end becomes unsetted and wants to break away in an unprogressive way - very weird behaviour. In the dry the car was a peach before and behaved in a totally predictable manner. Obviously the tyres are brand new and there will be various chemicals that need to be scrubbed off before I can form a true picture, and I will play with the pressures also to see if this helps. They are currently on 34psi. With a forthcoming euro trip in less than 2 weeks, I am hoping that a few more miles on them will see a marked improvement - as others seem to rave about the tyre. We will see................... in the meantime, any advice would be welcomed. Cheers
#524
#526
You'll probably be alright, but I wouldn't want to be running an under rated tyre on the road incase something went wrong and my insurance found out thee tyres weren't designed for the load that the car can put on them. On track I have thought the higher load a tyre can take the better too, up to a point of course.
#527
Originally Posted by s2k_Nut' timestamp='1432993339' post='23630059
[quote name='Rich 3' timestamp='1432992586' post='23630051']
[/quote]
'The speed rating means the tyre can be run at it's maximum speed AND at it's maximum load for an extended period without overheating.'
My link
#528
Anyone used Nankang NS-2R? Wondering how they compare over federals?
Have to go the same 225/45/17 & 255/40/17 as per the federals I believe.
Similar in price (literally like £2) but rate higher generally and used in a few competitions such as the civic cup
#529
UK Moderator
Type "Nankang" into the search box at the top of the thread and you'll see a few opinions about these.
#530
