Tyre Width
Old Jun 13, 2011 | 09:34 AM
NineBolts's Avatar
Default Tyre Width
I've got a nice set of Rays wheels on the car at the moment:
Smoked Chrome CE28N's (Front-17x7.5 ET+50, Rear-17x9.0 ET+63)
When I got these of Mike they came with Goodyear F1 GSD3 (Front-215/45ZR17, Rear-255/40ZR17) Although I think he had previously run 225 fronts.
Looks like the GSD3 are going out of production in these sizes and I've not been as happy as I was with the Goodyear Asymetrics.
I can't get the Asymetric or the Asymetric 2 in the 255 width for the rear, will a 245/40 be OK on a 9" wheel?
similar questions for the front although I can get a 225 Asymetric - should I go wider or stick with the oem width I have at the moment?
The car is about 30mm lower than standard and running a touch of extra neg camber.
obviously I don't want to order £500-600 on tyres and find they rub on anything or are too stretched.
Old Jun 13, 2011 | 09:36 AM
WinFreak's Avatar
The 9" wheel is only half an inch wider than oem so that's never going to cause any problems fitting 245 tyre.
They'll be a bit more stretched but I doubt you'll even see that.
Old Jun 13, 2011 | 11:19 AM
NineBolts's Avatar
looking very much like oem sizes and Goodyear Asymetric 2s all round for the next tyre change then.
Old Jun 13, 2011 | 11:45 AM
MIP's Avatar
MIP
Good choice.
Old Jun 13, 2011 | 04:01 PM
MB's Avatar
MB
Member
Tyre widths do seem to vary from manufacturer, iirc the oem RE050 is slim fitting, where most are a bit wider in the same sizes.
I did find a website which gave all the dimensions somewhere...
Bit I'd probably be going for 215 and 255.
R5HKK
Mar 12, 2018 05:28 AM
Ellzy
Jan 25, 2015 12:11 PM
har-vey
Jan 9, 2012 01:53 AM
S2000_UK
Jan 30, 2006 09:14 AM
lucky77
Jan 5, 2006 12:14 PM
