Upgrading fuel pump?
Old Sep 23, 2005 | 12:48 AM
MB's Avatar
MB
Member
Default Upgrading fuel pump?
Ok, changing the fuel pump today but to drain the system I need to crank the car without it firing (about 15 secs)
Need to know which fuse to pull under the dash.
A diagram of the whole thing would be nice too!
Thanks,
MB
Old Sep 23, 2005 | 12:54 AM
MB's Avatar
MB
Member
Got it - number 12 Second up on the left
Manual is useful for something then!
MB
Old Sep 23, 2005 | 01:31 AM
Trip's Avatar
Hey mark,
Do you need to empty the tank for this swap. IIRC the Honda guys did not do this on my car to change the fuel filter.
Old Sep 23, 2005 | 02:38 AM
MB's Avatar
MB
Member
Hi Trip,
Doesnt need empying, but better to have a low fuel level before you do it. Also best to do it outside in a well ventilated area. Id let the tenk vent off for a bit after removing the pump.
MB
Old Sep 23, 2005 | 03:17 AM
Trip's Avatar
but you will miss the after effects
Old Sep 23, 2005 | 03:18 AM
MB's Avatar
MB
Member
Could be interesting...! You try it and let me know how you get on
MB
Old Sep 23, 2005 | 03:45 AM
simonprelude's Avatar
Already further down the line than I got on the S/C install then
Old Sep 23, 2005 | 05:15 AM
Herbo's Avatar
Fuel pump change is a bit fiddly but not too difficult, space is a problem I found getting the rear panels off. Be careful not to break the small stud-clip that holds the pre-filter to the bottom of the pump, it can be opened gently with a small screwdriver and re-used.
Herbo.
Old Sep 23, 2005 | 05:22 AM
Trip's Avatar
^ Removing the passenger seat will help also IMO
Old Sep 23, 2005 | 06:09 AM
MB's Avatar
MB
Member
Thanks both
Simon, was going to do a fair bit today but rain stopped play! Was going to use parents garage but its full of stuff
Fuel pump was the 1st job then the pulley and so on... Pump will run fine with the standard reg short term. Will try again Sunday!
MB
