UREA grease discontunued
Old 05-04-2010, 05:21 AM
cupracing's Avatar
Default UREA grease discontunued
Im after some UREA grease to sort the ringing shifter out but Honda says its discontinued. So for those of you that have sorted your ringing shifter using alternative grease. What did you use?
Old 03-02-2012, 12:37 AM
RichwiththeS2000's Avatar
Was looking to regrease my shifter but also discovered Honda no longer sell the super high temp grease. What can/should be used instead?
Old 03-02-2012, 12:42 AM
LTB
LTB's Avatar
Piss !
Old 03-02-2012, 12:52 AM
Now I know!
Old 03-02-2012, 12:54 AM
Administrator
AquilaEagle's Avatar
Another high temp polyurea grease would do I suspect
Old 03-02-2012, 12:59 AM
Thats what I thought, only problem is the ones I've found just seem to label themselves as "grease" and don't give any clue as to what type exactly..
http://www.ebay.co.uk/itm/COMMA-CV-J...item336d3d8d0b
CV Joint grease apparently should be fine? Might just give that a go
Old 03-02-2012, 01:01 AM
Administrator
Found this:
http://www.bernardip...08798-9002.aspx
http://www.inlinefou...suhiteurgr.html
Or would this do? I'm not sure:
http://uk.rs-online....7633D4E4F4E4526
http://uk.rs-online.com/web/p/indust...cants/0692671/
Old 03-02-2012, 01:07 AM
Thanks, apparently neither ship outside the US
Old 03-02-2012, 01:17 AM
Administrator
Look at the 2 bottom links, it's a UK company and both of those are high temp greases - they are just not polyurea. The first one looks like it is higher temp
Old 03-02-2012, 02:32 AM
yorkies2k's Avatar
Try Silkolene PRO RG2 Racing Grease. Opie recommended it as an alternative
Ive used this on mine and worked a treat. Also good for clutch fork as it clings to the surface of what ever you put it on
Quick Reply: UREA grease discontunued
