Valve rocker arm assembly
Right, I'm just almost finished rebuilding my engine and have discovered that the rocker arm assembly has been messed with before, I think. In one of the arms/butterflies I found what I can only describe as a wrist pin, was actually smaller than all the others and also had no hole in the middle like the others. Now I don't know if its like that or if someone has messed with it before as it has been rebuilt before as the dreaded #4 got scratched. Funnily enough the problem with the assembly is the one over #4.
Heres some pics to get an idea, what I need is to be able to just find that one 'wrist pin' so I can complete the build, else I'll have to buy a whole new arm assembly, not good!
ok, the solid one is supposed to be in the rocker which takes the high pressure feed from the rockershafts. this is then forced out when the ECU switches on the vtec valve. this will in turn push the middle one out against the sprung loaded pin in the other rocker locking the whole lot together.
i'll send a complete assembly rather than just the pins
Originally Posted by s2000 gib,Dec 7 2008, 08:15 PM
ok then cheers, just pm me and let me know how much to paypal you.
Originally Posted by B0ZWELL,Dec 9 2008, 07:21 PM
posted the three rockers today. it was only a couple of quid so don't worry about payment
JD_S2K and m1bjr - totally right about helpful. I've come across a few helpful guys on this forum and have helped immensely with this rebuild. Taken ages (15months) but would've taken longer if it had'nt have been for guys like bozwell, bibbs, bassoctopus etc
