Vibration under acceleration
Old 04-03-2017, 01:40 AM
S2Bray's Avatar
Default Vibration under acceleration
... and not drive shaft cup wear - they've been swapped in an effort to rid me of this vibration.
Most noticeable between around 4-5000rpm, under load; either hard acceleration or increased effort going up hills. If I knock it out of gear of back off, the vibration stops/eases
I'm inclined to think for that reason, and that I have 2 sets of wheels and the symptoms are consistent, that its not out of balance wheels.
It definitely feels like it comes from the rear.
Any thoughts?
Old 04-03-2017, 01:50 AM
johnckeen's Avatar
diff...? maybe mounts are shagged?
Old 04-03-2017, 02:23 AM
S2Bray's Avatar
Don't suppose you know how to inspect/what to look for to assess diff mounts?
Old 04-03-2017, 02:25 AM
har-vey's Avatar
There rubber mounts so check for cracks or splits
Old 04-03-2017, 02:29 AM
nomadicS2k's Avatar
I would check for excessive movement on the diff - this is possibly the less likely option - the more likely option is the rear drive shaft joints need checking and have work (although still I would expect this at all rpm's)
Couple of bits of reading:
Link 1
Link 2
Old 04-04-2017, 07:38 AM
S2Bray's Avatar
Thanks for the comments.
With regards to diff mounts - when jacking up the rear of the car (on the diff), how much movement/slack would you expect the diff to take up before lifting the car. I reckon mine moves maybe 10mm before it 'bottoms out' and lifts the car. If this is excessive, I reckon I may have found the culprit!
Old 04-04-2017, 09:32 AM
Winstan's Avatar
When i jack my car up from the diff there is no noticable play. Definitely not 10mm before lift, looks like you found your culprit. If not i would say its beneficial to replace the mounts regardless.
Old 04-04-2017, 10:59 PM
S2Bray's Avatar
Thanks mate. This is good news! ...sort of.
Old 04-05-2017, 05:06 AM
miloking's Avatar
Any thoughts?
ahhh i see you already swaped cups... did you just swap them left to right or got some new ones?
Old 04-05-2017, 05:23 AM
S2Bray's Avatar
Swapped left to right. They weren't noticeably warn though. Which perhaps isn't all that surprising given it didn't fix the problem.
Quick Reply: Vibration under acceleration
