VTEC Controllers?
Old Jul 5, 2006 | 05:35 AM
Nath's Avatar
Default VTEC Controllers?
A mates got one on his Civic VTI and he said that its a cool peice of equiptment , he has set his VTEC to come in at 4750rpm.
Anyone got any experiance of these on there S2K's???
He has this one
http://www.buddyclubuk.com/buddyindex/what...B%20SITE---.htm
pretty cheap for what it it?
Old Jul 5, 2006 | 06:19 AM
MB's Avatar
MB
Member
Set his VTEC to 4750?! That shows some clever thinking
These things dont map the fuelling or ignition timing - so it would be very unwise to do that.
Its cheap for a reason.
If you want power then look for a remap or an aftermarket ECU. Apexi VAFC is also an option, but needs rolling road tuning.
MB
Old Jul 5, 2006 | 06:39 AM
Bibbs's Avatar
I've got a Apexi, you can map the fueling for the changes you make
(otherwise it makes your car slower - the cross over point is there as it's the optimum).
Mine was on a rolling road for about an hour and a half. managed to drop the vtec point to about 5,400 and then up the fueling to compensate .. made about 4bhp at the top end, but the curve was flatter (no dip to the stock vtec point).
Old Jul 5, 2006 | 06:42 AM
MB's Avatar
MB
Member
If they did one that altered the timing it would be an even better bit of kit - thats where the extra gains are from. Effectively it would be a fully working piggyback controller.
Do you find you have to reset your ECU to stop the ECU learning its old ways Bibbs?
MB
Old Jul 5, 2006 | 06:50 AM
Bibbs's Avatar
Apexi did a timing controller to go with the rest of the range.
RSM - Speed cut
SAFC - Fuel Controller
VAFC - Fuel & Vtec Controller
AVCR - Boost Controller
(I've had all on one car or another - RSM & VAFC on the S2000)
But when they went from Gen1 to the Gen2 design .. they dropped it.
They are just releasing their Gen3 models (colour displays etc) so hope they re-introduce one.
The PowerFC does the lot, but not seen one for the S2000.
The ECU does need to reset, I'm going to tap in two buttons, one to cut the backup power (ECU Reset) and another to get the ECL flashing.
I found the car was quicker, but the vtec transition was so smooth you could only tell the change from the sound. So I've stored the settings and re-set it .. for general driving, I'm a fan of the V-tec kick (must be from my old turbo days) .
Old Jul 5, 2006 | 08:21 AM
AquilaEagle's Avatar
Administrator
BANG!!!
Old Jul 5, 2006 | 01:30 PM
mikey k's Avatar
You lost another engine Ian
s2k_ed
Mar 14, 2009 11:23 PM
viets2k
Jan 28, 2007 04:48 AM
BELGIUMPAUL
Oct 20, 2005 11:27 AM
Cyber Logic
Mar 10, 2002 07:29 PM
dbkelly
Feb 23, 2001 09:29 AM
