VTEC failure ?
Old Feb 24, 2008 | 02:10 PM
simonprelude's Avatar
Default VTEC failure ?
.......might still be the case, again.
Going up hill, clear road, very damp though.
NSL road and Golf doing about 40mph in front of me so I drop it to third and floor it.
As soon as the cam switch over should come all power was lost, ABS and CEL came on for a split second and I had to let the Golf go passed on the inside so I could pull over and see what had happened.
As soon as I came to a stop the engine stalled / switched off.
Quick look under the bonnet and everything still seems to be in the correct place.
Go to start the car again, turn the key and all seems normal, press the button and all the electrics turn off. Turn key again and all is fine, engine sounds a little rough but that could be the ECU learning again ??
The windows had reset to manual only, but the stereo still held the security code and station preset data.
Any idea what has happened ????
Old Feb 24, 2008 | 02:12 PM
GrittyShaker's Avatar
That's pretty much what mine did when my speedo convertor was drowned. Not sure what would be causing yours however.
Old Feb 24, 2008 | 02:17 PM
chrisr111's Avatar
This happend once to my brother in his DC2, it never did it again. I don't know the cause I'm afraid. Have you checked the oil?
Chris.
Old Feb 24, 2008 | 02:29 PM
MB's Avatar
MB
Member
Didn't knock the key did you Simon?
Old Feb 24, 2008 | 02:31 PM
RISLAR's Avatar
That old chestnut
Old Feb 24, 2008 | 02:48 PM
Don't think so
Oil is 1 notch from the top, checked yesterday morning and driven 15 miles since.
Old Feb 24, 2008 | 03:39 PM
Ultra_Nexus's Avatar
Sounds like a fuel problem - might have been your fuel pump on its way out, exactly the same thing has happened to me and it was fuel pump.
Although didn't have any problem with my windows, but then I wasn't in an NSX!
Old Feb 24, 2008 | 11:53 PM
Shipley's Avatar
Are your battery terminals tight ?
This happened to me in an Alfa once and it turned out the negative lead was loose.
Old Feb 25, 2008 | 12:00 AM
K4RL's Avatar
Check the Fault code. i had a problem with the VTEC Solinoid 1592 i think could be that ? it happens during cross over.
Old Feb 25, 2008 | 01:29 AM
veehexx's Avatar
main relay faulty? i know fairly common on certain hondas with complete power loss....
