vtec hesitation
did a search and found various threads about map sensors etc.. just wondering if I can give it a tap here at work or if its best left to the workshop?
also I had an oil warning light come on the other day whilst on a steep hill, checked level and it was a bit low but nothing drastic, would that light just have been to the incline?
thanks for any help
thanks for any help
Its most likely to be the MAP sensor. Happens to mine regularly.
Get something with a non metallic handle (like a screwdriver), I have however used my mobile phone before
...and give the MAP sensor a few sharp taps.
As if by magic..the car responds perfectly.
You don't have to take the sensor off
...and give the MAP sensor a few sharp taps.As if by magic..the car responds perfectly.
I had this a stuttering and hesitency in VTEC.
Read about the old map sensor thing and laughed to myself..............."that will never work.............."
Gave it a tap with a screwdriver handle and its been fine since!!!!
The dealer would probably do the same but charge you
hehe, I can't wait to try this
sounds too good to be true
reminds me of a squeal I used to get in my scoob, sounded like the front diff was going, all the symptons etc.. took it to a garage and they said it was a big job, one guy suggested top up the power steering before parting with my hard earned - five quid later and my car was perfect again.
does make you wonder about garages :S
thanks for the great advice btw
found it thanks
here it is for anyone else who might want to try it
https://www.s2ki.com/forums/index.php?showtopic=209708
