VTEC probs
Old Jul 7, 2005 | 11:57 AM
slikts2000's Avatar
Default VTEC probs
Ive just started having a prob when in VTEC, it feels like a petrol blockage (if you understand what i mean) and then it goes, it feels like a powerr loss, its not all the time and the oil level is fine, which is made me worried, any ideas. . .?
Old Jul 7, 2005 | 12:07 PM
Amuse Boy's Avatar
Reset the ECU by disconnecting the neative battery terminal for 5 or 10 mins and also give the map sensor a whack. That should sort your problem.
Do a search for "map sensor" and you'll get more info.
Old Jul 7, 2005 | 01:00 PM
Shipley's Avatar
Its your MAP sensor. Its nothing to worry about...just needs a little friendly tap
Old Jul 7, 2005 | 01:07 PM
Bassoctopus's Avatar
Or you could look in the faq
Old Jul 7, 2005 | 01:20 PM
slikts2000's Avatar
doh. . . cheers
Old Jul 8, 2005 | 12:34 AM
me11jh's Avatar
Definately your MAP sensor, had the very same thing with my car. Don't worry, easily fixed with a tap.
Old Jul 8, 2005 | 01:08 AM
lower's Avatar
if it feels like the power is coming and going and the car is dropping in and out of vtec, and your fuel consumption has worsened then i had exactly the same thing. disconnect and reconnect the map sensor and give it a tap as the others have said. worked for me.
Old Jul 8, 2005 | 01:10 AM
Neil.H's Avatar
Another vote for MAP sensor.
Old Jul 8, 2005 | 02:19 AM
AdrianEagle's Avatar
All 2004 and 2005 are being given new MAP sensors to fix just this problem. If I remember the Honda Service Bulletin is 622. Try your dealer to see if they will do yours even though it is a bit older!
Old Jul 8, 2005 | 03:04 AM
slikts2000's Avatar
Cheers guys, i did the map sensor knock and reset the ECU and drives lurrrvvvly now, one thing tho, after i reconnected the battery, i activated the alarm and it chirped twice like a normal alarm, which i like as i know i put it on, the trouble is it only did it the once, any ideas. . .?
SHAKYBRAKE
Jul 12, 2018 05:31 AM
beefystud
Jun 24, 2014 09:01 PM
will gill
Nov 26, 2004 08:17 AM
EddandSam
Nov 19, 2003 08:36 AM
