VTEC issue
Old Dec 1, 2014 | 01:39 PM
Booti's Avatar
Default VTEC issue
Apologies if this has been asked before, I couldn't find anything in the search
This morning I was starting a journey with a short run down the M25. As I drove down the slip road I opened it up in 2nd and as the cams open at about 6k, the engine suddenly lost all power like it was severely engine braking. It pushed me forward in the seat it was that sudden.
Dipped the clutch, no warning lights, engine still running. Put it into 3rd and it was fine.
It has done the rest of the journey home to Manchester without issue.
The VTEC was fine coming out of the M6 Toll road later on
I know the oil level was fine as I had just checked it after a long drive on Sunday. Could it just be the engine wasn't warm enough, or could it be another (more serious) issue please?
Old Dec 1, 2014 | 01:50 PM
s2konroids's Avatar
Coolant temp too low that prevents vtec engagement.
Old Dec 1, 2014 | 02:38 PM
Ian Lillystone's Avatar
That sounds like you've hit the Rev limiter, no?
Old Dec 1, 2014 | 03:21 PM
weatyGT's Avatar
Or your vtec oil pressure switch is dodgy, pop it off give it a clean and pop back on. Be csreful of the pins... the plastic trim couldve cracked and a loss of connection for a secknd or ao may give you the no vtec available that you experienced, usually the ecu light pops on but worth a check anyway i guess
Old Dec 1, 2014 | 09:19 PM
Riknos's Avatar
My bet is on this, especially as it hit vtec fine later on. Just remember to warm the car up properly before vtec'ing! Also, remember it's cold this time of year so takes longer to warm up.
Old Dec 2, 2014 | 09:51 AM
Booti's Avatar
thanks, hopefully with this confirmation, its as simple as that, but ill keep an eye on it
It was almost that kind of feeling, but it happened at just over 6k
I will do some digging on where this is located and have a look / clean. Thanks
Old Dec 2, 2014 | 11:54 AM
tobyCHIPPO's Avatar
Sounds like the car is too cold. Also just because your coolant is up to temp doesn't mean your oil is, so you shouldn't be vtec'ing Just because the coolant is hot.
This becomes more evident when you have gauges like myself
Old Dec 2, 2014 | 12:16 PM
weatyGT's Avatar
Vtec oil pressure switch is on front of engine just by the TCT... right of the manifold. Hth
Old Dec 2, 2014 | 01:32 PM
tangoray's Avatar
dude you hit the 'engines not warm enough what the f@ck do you think you playing at son' limiter.....all will be well, i did it once and shit myself thinking id screwed something up haha....never done it since, i doubt you will either
Old Dec 2, 2014 | 01:43 PM
Fatbloke's Avatar
It's a special feature that ensures people who give a cold engine a proper bootful of throttle post thread on here, so that the rest of us know not to buy a car off you
