what grade oil for engine/gearbox/diff ?
Old Jun 28, 2011 | 01:11 AM
Daren 83's Avatar
Default what grade oil for engine/gearbox/diff ?
as above can u tell me what's best grade oil? Im also using a richmand 4.56 final drive.also forgot what grade plugs would u reccomend? thanks
Old Jun 28, 2011 | 01:17 AM
Bandit_287's Avatar
https://www.s2ki.com/s2000/topic/131...ad-this-first/
Old Jun 28, 2011 | 01:20 AM
jsl20's Avatar
according to the FAQ its 10W-30 (or 10W-40), 75W-90 GL-5 and 5W-80 GL-4 for engine, diff and gearbox, respectively. i think the honda recommended 10W-30 is pretty rare though, none of the big guys seem to sell such a grade! if you're lucky like i was you might find a garage with a gallon or two spare!
Old Jun 28, 2011 | 01:32 AM
Daren 83's Avatar
thanks for that. with me using a richmand diff. would that be the same grade as the standard s? it's a tad noisy. just wondered if i change grade might make it a tad quiet?
Old Jun 28, 2011 | 01:46 AM
richmc's Avatar
Can't belive I'm reading this!
1. Go to the tech FAQ for info on oils
2. SEARCH and you will find
3. Most of the info you have been given so far is wrong.
SEARCH and you will find.
Old Jun 28, 2011 | 01:47 AM
MB's Avatar
MB
Member
What does the owners manual say?
Old Jun 28, 2011 | 01:54 AM
richmc's Avatar
Old Jun 28, 2011 | 01:58 AM
jsl20's Avatar
i'm just quoting from the FAQ itself-what was wrong?
Old Jun 28, 2011 | 02:42 AM
Daren 83's Avatar
did look at the section. but was just asking if i different grade diff oil would be needed as im using a richmond diff.if theres anything to make it abit more quiet?
Old Jun 28, 2011 | 03:11 AM
MB's Avatar
MB
Member
It shouldn't be too noisy, but a thicker or higher quality oil will quieten it down, although i'm not recommending you do that as it affects performance too.
