Wheel alignment in Suffolk
Old Jun 1, 2005 | 12:07 AM
Mangroa's Avatar
Default Wheel alignment in Suffolk
I think I've got a similar problem that a few people here have had.
I've noticed that the rear seems to slide out a bit when going round tight-ish bends. I'm not flooring as I've only had the car 2 weeks. It just feels like the back is sliding sidways over the ground. Tends to happen on more uneven surfaces. Its always been dry. I'd have thought I'd hear tyre squeal before it loose grip. Its silent. Straight line grip is fantastic. Even my gf was able to notice it from the passenger seat.
I was thinking that I need it aligned. However this morning I've discovered that the 1 rear was 33psi and the other 30psi. Could this be the cause? I'll see how it behaves today now I've adjusted them to 30psi (cold).
Otherwise I guess it need aligning. Can anyone suggest a good place round Ipswich, Suffolk???
Am I just being paranoid about my new toy???
Thanks
Alan
Old Jun 1, 2005 | 12:08 AM
Mangroa's Avatar
Forgot to say that the tyres are ES02JZ with a lot of tred left.
Old Jun 1, 2005 | 02:08 AM
markS2kcU's Avatar
Think its 32 psi when cold, you could try www.nemesisperformance.net they are just outside Colchester, I had mine done there a while ago and they seemed to have done a good job. Have a look in the FAQ and you can print out the specs you want the alignment set at.
Old Jun 1, 2005 | 02:26 AM
baptistsan's Avatar
Yep 32 psi all round.
Old Jun 1, 2005 | 06:23 AM
Mangroa's Avatar
Opps!
I'll set them to 32psi
Thanks!
Old Jun 1, 2005 | 09:22 AM
s2uk's Avatar
depends where in suffolk you live, head out to stortford perfoamnce wheels and tyres, they also have a branch in cambridge but th ebishop stortford bunch have newer machinery and do alot more alignments. 01279 466 466 speak to barry. well worth going a bit further a field for it.
iandavidcassidy
Nov 12, 2006 01:07 PM
Mans Best
Sep 28, 2005 05:08 AM
Hbrowni
Jun 7, 2005 12:48 PM
spankley
May 23, 2005 09:08 AM
honpar
Oct 8, 2003 10:27 AM
