Wheel studs
Old Nov 13, 2010 | 06:24 AM
Madfish's Avatar
Default Wheel studs
Can the studs be replaced on these cars or is it a case of buying a new hub? I've just bought some RAYS wheel nuts and i've managed to ruin one of them on a dodgy cross threaded wheel stud (was not crossed by me)
Thanks,
Mark
Old Nov 13, 2010 | 09:48 AM
TangoVTEC's Avatar
Yes the studs can be replaced, I've seen your other post with pictures and I'm guessing its a front one?
IIRC for the front your going to have to pull the hub and bearing, then you can hammer out the old stud and knock in a new one, they are on a spline.
You should stick a new bearing on mind.
I'm sure someone will be along to correct me if I'm wrong........
Old Nov 13, 2010 | 10:07 AM
Madfish's Avatar
Cheers dude, yeah, it's the front one i've had to stick an old steel one on for now. Just seing if the RAYS nut is salvageable as it's only the first 4-5 threads that are damaged inside...
Thanks,
Mark
Old Nov 13, 2010 | 10:26 AM
Wobbly's Avatar
Could you get away with running a die down the stud to try and salvage it?
Old Nov 13, 2010 | 10:28 AM
Madfish's Avatar
Might be a worth a shot, sure...
Old Nov 13, 2010 | 10:29 AM
Wobbly's Avatar
In fact the tap might save the nut
Old Nov 13, 2010 | 02:24 PM
r8byb's Avatar
Banned
Running four would be ok.
dam2
Nov 6, 2013 08:39 AM
954chris
Jul 26, 2013 12:51 PM
grandprixwhiteap1
Dec 14, 2009 12:47 PM
kitwetzler
Oct 19, 2004 12:58 PM
mikecl713
Sep 23, 2004 11:33 PM
