Wheels for a beginner
I understand nothing about wheels, except what I like the look of.
What measurements and stuff do I need to know, and what fits the S !!!
the wheels I am looking at come in:
7.0x17
7.5x17
7.5x18
8.0x18
9.5x18
Make any sense to anybody ?
7.0x17
7.5x17
7.5x18
8.0x18
9.5x18
All details of the stuff on my car are in my sig. Basically you need the same rolling diameter (wheel + tyre) If you go wider you need to change the offset to make it fits in the arches (& drives proper!) The correct fitments for the S seem to be very limited in the UK with out importing exotica!!
Try this thread for some options!
https://www.s2ki.com/forums/index.ph...&f=25&t=243091
no, you need to know the offset too. (i.e how far the hub of the wheel is from the in/outside of the rim of the wheel) If it is in the wrong place, the wheels might rub on the inside, or poke out too far from the body.
From your list...
7.5x18 - Front
8.0x18 - Rear
Is what you want, imho.
8.5x18 rear would have been better, but I suspect 9.5x18 may be too much. (although I know a fella with 10.0x18 )
It all depends on the offset really. You see, if they "stick out" from the wheel arch too far they maybe considered illegal.
7.5x18 - Front
8.0x18 - Rear
Administrator
I had no clue about this and bought some off a previous S, so i knew they fitted
Tire and Wheel Forum will help, despite being USA predominantly Jim@Tire Rack is very helpful there And all the info you need will be there too
