Whining (pun)
Old Jun 26, 2007 | 12:21 PM
rabsee's Avatar
Default Whining (pun)
OK - I give up, I'm not mechanically minded and I don't know what it is!
My 03 37k miles, has an annoying whine when throttling back in say 3rd and 4th around 3 to 4000 revs. Amethyst Honda (Gloucester) have so far changed the clutch, flywheel, and GEARBOX! all at no cost (Hondacare) great service, but it's still there!!!! Quite seriously, I know what revs I'm doing in traffic without looking.
What the hell is it???? Is it normal?
Last point at around 50mph, in neutral and coasting, a very similar noise can be heard!?! May not be related.
Old Jun 26, 2007 | 12:26 PM
motogp1's Avatar
lsd ?
dont coast in neutral as this is not good for lsd
Old Jun 26, 2007 | 01:25 PM
RedUn's Avatar
How loud is the noise?
Rick
Old Jun 26, 2007 | 01:34 PM
Jonsey Boy!'s Avatar
I don't want to hijack this but was the clutch and gearbox replaced under the used hondacare warranty, or was it replaced under the original 3 year warranty?
Cheers
Old Jun 26, 2007 | 09:36 PM
mikdys's Avatar
At cruise if you accelerate slightly does the whine dissappear, and then come back when you take your foot off the throttle? Does the noise come from the back of the car? Is the right oil in your differential (did a dealer change this for you recently at a 36k service)?
Sounds like it could be the diff at a guess....
Old Jun 26, 2007 | 11:16 PM
lower's Avatar
Originally Posted by motogp1,Jun 26 2007, 09:26 PM
lsd ?
why is that?
its a torsen diff. nothing wrong with coasting in neutral from a mechanical point of view with that sort of diff.
Old Jun 27, 2007 | 08:12 AM
motogp1's Avatar
Originally Posted by lower,Jun 26 2007, 11:16 PM
why is that?
its been advised on here a few times not to coast in neutral as its not good for the lsd , the same as aa/rac never tow the s always flatbed truck.
but im probably wrong !
Old Jun 27, 2007 | 08:16 AM
Nick Graves's Avatar
I'd have started with the Diff, TBH.
Mind you, since it's all that's left...
Old Jun 27, 2007 | 09:13 AM
m1bjr's Avatar
Diff, most likely, or if you're lucky the CV joint on the end of the prop.
RobboC
May 20, 2010 08:16 AM
arins2k
Jan 20, 2010 08:53 AM
David1
Oct 10, 2003 05:48 PM
OHDABEE
Sep 30, 2003 07:55 AM
hallerma
Apr 12, 2002 03:33 PM
