Windscreen misting up!!!
Old Sep 10, 2003 | 06:52 AM
steve_the_greek's Avatar
Originally posted by potfish
You need to use it once a week or so anyway to keep the seals in good shape, so might as well do it all at the same time eh?
I find the problem with using the aircon is that although it provides instant demisting, as soon as you switch it off when the windscreen's clear, the moisture that it's extracted which collects in the aircon condensor starts to evaporate and works its way back to the screen after a few minutes.
Old Sep 10, 2003 | 06:57 AM
JamieS2K's Avatar
Old Sep 10, 2003 | 08:10 AM
dws2000's Avatar
You keep seals in your car, does the RSPCA know?
Sorry, end of day silliness - on a more normal note which seals do you mean? around the windscreen or elsewhere as well?
Old Sep 10, 2003 | 10:56 AM
Beardie's Avatar
Manual says that you need to use the aircon once a week to keep the aircon seals in good nick.
Old Sep 10, 2003 | 01:03 PM
JamieS2K's Avatar
Yes indeed this is correct , I do turn mine on at least once a week but only for a few mins !
Old Sep 11, 2003 | 01:25 AM
Colin Andrews's Avatar
too! It's one of those vicious circle situations. It seems to me that if you use the aircon to de-mist, it helps the screen fog up again when it goes off. If you want to stop the screen from misting, without using the aircon, you have to avoid using it at all - no quick a/c blast to get it started.
I think having a less than sparkling screen doesn't help misting either (that won't apply to anyone here of course )
On the other hand, I have 237bhp at my disposal - I reckon I can give up 3 in order to see which way I'm going.
Here's a potential mod for the tech minded - how about a WOT switch to disable the aircon? If you don't know the WOT acronym, don't try this
Ok WOT = Wide Open Throttle
I've often thought a Nitrous Oxide Timer actuated by a WOT switch would be great - Wot's that? That's my WOT NOT .... I'll get me coat
Old Sep 11, 2003 | 08:22 AM
argep's Avatar
It's all pants. Mine seems to mist up aicon, no aircon, recirc, not recirc, cold, hot, what the hell!! Perhaps it's the damn seal spitting water up.
Old Sep 11, 2003 | 08:35 AM
JamieS2K's Avatar
Just buy some rain x from tesco's in braintree . I got some yesterday and have had no misting up since !!!! Only been on eday I know but when it rains is the worse !!!
y0itzCARL
Jan 13, 2010 02:37 PM
Bassoctopus
Sep 10, 2005 11:45 AM
xman
Aug 28, 2005 08:08 PM
VAG
Jan 19, 2005 07:25 AM
Cossa
Apr 30, 2004 06:26 AM
