Windscreen surround rust
As I see it the only way to sort that properly is with the windscreen removed and a proper body shop doing the work, If that goes to a hole then it could be a nasty problem.
Grind it back and then see how deep it goes. I'd also be inclined to have someone carefully weld a piece of metal in there or plate over it and then grind it flat and paint over it as a body shop would.
Thanks for the replies.
This sounds like it is going to be an expensive job.
Going to do what I can first and then if it gets worse (which it will) I will get a body shop to fix it.
Rust is really ruining my S2k vibe right now.
if you can work your way around the insurance company with the fact the screen will need removing rather than it having been subjected to accidental/malicious damage.
Highly doubt it'd do the windscreen in upon removal. They're Triple layered laminate reinforced glass. Providing it's got no major chips, it's not as if they're going to flex the glass.
The wire they use to cut the adhesive is sharper than a stanley knife blade.
