Windscreen washer jets
Old Dec 30, 2012 | 06:16 AM
Dhaval85's Avatar
Default Windscreen washer jets
Hi,
I have a problem with the jets for the windscreen whereby when I try to spray water onto the windscreen nothing comes through.
After reading a couple of posts and removing the rubber pipes, I tested them and they were fine.
The y connector also looks fine and with all the pipes removed I tried to spray the water and nothing suggesting water isn't even reaching first pipe but seems very strange as the headlight washer jets work fine.
Anyone have any ideas or know anyone I could go to?
Thanks
Old Dec 30, 2012 | 06:25 AM
Moddiction's Avatar
Former Sponsor
Fluid in the tank? Haha I'd assume yes. Do you hear the pump motor when you go to spray them? All lines connected going into the reservoir? I know the connector by the good hinge can come off sometimes if you haven't checked that.
Old Dec 30, 2012 | 06:35 AM
Dhaval85's Avatar
Yes fluid in tank (assume headlight washer jets dont have separate tank and they work fine)
I think there was a slight noise from the pump but will try and check tomorrow/Tuesday because that is what led me to believe potentially the y connector but no such luck.
If I can hear the pump any other suggestions? Where are the pumps located? Is it easy to check/access?
Thanks
Old Dec 30, 2012 | 06:37 AM
Dhaval85's Avatar
Where/what do you mean? Not sure about where this connector would be
Old Dec 30, 2012 | 06:51 AM
Scottland's Avatar
Open the bonnet, to the left near the hinge for the bonnet is a flexible rubber pipe that can pop off.
Old Dec 30, 2012 | 06:55 AM
Dhaval85's Avatar
Oh that one is fine as disconnected all from There up however when i try to squirt the water no fluids cpming out of that pipe when all disconnected
Old Dec 30, 2012 | 10:09 AM
CHIPPO's Avatar
One tank with 2 pumps, one for the screen , one for the head lights .
The screen ones do fail and cost a packet from Honda , its buried in the bottom of the tank behind the arch liner in the offside wheel arch.
I believe some people have had success with an aftermarket or Pug pump.
Also that small pipe can get creased/folded where its goes up onto the bonnet and can stop the flow.
Old Dec 30, 2012 | 12:09 PM
MI5's Avatar
MI5
I will tell you exactly what it is. Just before each jet outlet there is an inline non-return valve. These are for ever seizing up on the flow side with the ball bearing inside them becoming loose and blocking the outlet.
Easiest way to check is to remove the inline valve and put a straight through connector. If the water then comes out the jet when operated you have your cause.
Old Dec 30, 2012 | 12:13 PM
Dhaval85's Avatar
Thanks MI5 and CHIPPO.
I need to try and get behind the arch to have a look but will wait for weather to be a bit better than it is currently. Good thing it isn't my main car otgerwise with the screen wash It could be problematic.
@MI5 - I have removed all the pipes and left on the one coming from wing around hinge of bonnet and when you pull stalk for spray there is nothing and therefore looks like pump rather then valve as fluid is not even reachibg that far.
Thanks again guys
Old Dec 30, 2012 | 12:36 PM
GreenmanS2000's Avatar
I had the same problem but I balked at £95 Honda wanted for a new pump - £6.00 off fleabay for a new pump will sort you out.
