Windscreen Washers
Windscreen Washers
My screen wash fluid has developed the most horrendous smell, a cros between PVA glue and Gin, it seems to be fermenting. I am tempted to try tonic and lemon!
Have flushed it out and tried new screen wash and at higher concentration, but after a week smeel even worse, it seems to feed the fermentation?
Should i try flushing with just water and leave hjust water ?
Or maybe a touch of mild bleach, Milton type stuff as used for babies nappies etc?
Does any one have any ideas LOL
What brand of screenwash are you using? Gordans, Bombay or Unibond?
Seriously...try a different brand of screenwash and see if it makes a difference. Some have a higher Ethyl alcohol content, as an antifreeze, than others.
I did try smirnoff but had troble getting it in the glass witout spilling the tonic or ice, the best gin was Plymouth!!!!!
This is now the third flavour screen wash, Halfords, previously comma and a non descrip other, the Halfords is at the very concentrated low temp conentration, and this seemed to makes things worse, i bleieve some bactiera feed on alcohol so maybe this is the problem, hence my comment regarding no additives or bleach ?
I had this issue. My car is a weekend driver and I dont use that much windscreen fluid. Assumed it must have gone off as smelt vinegary and very acrid. Took me a while to work out what it was, almost smelt like burnt pollen which made me thing I might have had a heater vent clog up or something.
Pulled all the fluid through and held my nose. Filled up the bottle and pulled through again, and then filled up half way with some fresh fluid. Was using Halfords own brand for the record.
Originally Posted by MedicUK,Sep 10 2008, 03:08 PM
Try Milton they use it to clean baby bottles
Used to use Milton to flush out the drinking water system on my boat. Will kill any bacteria and won't do your washer system any harm at all.
