Yet another happy Center Gravity customer.
Old 05-22-2007 | 01:19 AM
  #31
Dembo's Avatar
Originally Posted by chilled,May 22 2007, 09:30 AM
However on my next session I started to use the lift off oversteer that Chris had dialled in. This was particularly useful at Kirkby, the sort of dual lefthander after pif paf.
Just spent ages looking for a map of corners so I could see what you were talking about (there's one on BAT's site ).
Sounds the same as mine, but I was doing it more into Pif Paf (that's the slower chicane that looks like a hairpin): lifting off slightly on the way in to let the car oversteer until it was pointing the way I wanted and then using more throttle. I seem to be getting good at doing that on chicanes and dual corners like that: let it oversteer on the way in because you know you're about to turn the opposite way anyway. Works well on the twisties after Hatzenbach, and at Hockheim (I think that's where I mean).
This is what's so great about my car now Chris has worked his magic: it feels like you can just play with oversteer and understeer all without any drama.
What I have found works really well for me is setting my rear dampers stiffer than the front. This means the rear rolls slower into the corner (so turn in oversteer), and takes longer to roll back on exit (so exit understeer and more rear traction to overcome it). I imagine you'd like that.
And I hearby take back what I said about caster. I thought it was great yesterday.
Old 05-22-2007 | 01:30 AM
  #32
Paper Lawyer's Avatar
I've got some longer front springs sitting on the desk in front of me I'm going to raise the front end a few millimetres (the driver's side is 4mm too low at present anyway, hence the front lip scrubbing a little as I turn into the hairpin from the banking).
Then it's a question of waiting for Powerflex to supply Chris the ARB bushes and I'll be over there to get the stiffer Tanabe rear ARB installed and I can then play with the balance of the car by adjusting the drop link length, front and back
I felt that the rear of the car had too much roll on track with the rear OEM ARB - now I have the anti bump steer kit etc, the problems which I was seeking to address by (probably wrongly) returning to a rear OEM ARB should not resurface (fingers crossed!).
Old 05-22-2007 | 01:47 AM
  #33
chilled's Avatar
Pif paf isn't really a chicane. It's a lefthander. Hug the kerb around Chapman, then turn once to the left, and the straight before Kirkby gives you enough time to get back on line. That's one of the places on track I gained a lot of ground on traffic. And that info was from lower's instructor via lower
Old 05-22-2007 | 01:52 AM
  #34
Dembo's Avatar
As for the adjustable droplinks, assuming longer will have less of an effect I can't imagine you'd ever not want the full effect of the front. If it's like mine, you'll just be wanting to reduce oversteer by making the rears longer.
I feel like I've got some of the bumpsteer back. The rear ARB makes things worse over bumps with losing the independence of the rear suspension (as Nick had said somewhere). It's definitely not as stable as it was pre-ARB, but better overall with less roll, and less of that slightly unpleasent feeling you get when one end rolls more than the other.
Whiteline have a thing for stopping the ARB moving side to side (I think the OEMs have them), so I might get those for the rear and see if that improves things.
Old 05-22-2007 | 02:51 AM
  #35
lower's Avatar
yeah, the instruction i had straight after the sighting laps
I hadn't had a chance to get to learn the circuit, there was too much traffic, and because i was getting the lines right (ie under instruction) i kept catching other cars.
I ended up hanging back, doing 3 quick corners, hanging back, another 3 quick corners etc.
tekknikal
05-07-2010 07:47 PM
LTB
06-13-2009 11:11 AM
RobJ1
07-15-2007 09:22 AM
kitwetzler
08-23-2004 03:35 PM
Quick Reply: Yet another happy Center Gravity customer.
