Greddy Turbo Kit Install
Hey Guys,
I live in rochester and i recently bought a used greddy turbo kit.
It literally has everything i need, injectors, pump, oil relocation, clamps, bolts, gaskets, brackets, ecu.
The only thing i don't have is the turbo compressor outlet to the inter cooler pipe and the cold side charge pipe. Everything else should be accounted for.
So my question is, i would like this installed "professionally" despite it being a used kit. I don't have a big enough garage, and my mechanical skills are cringe worthy. Any suggestions or recommendations that can also fabricate the two pipes i need as well? After all, it is just a straight bolt on kit and other members have done it ~8 hour alone. Was hoping to get it completely done within two days MAX. I don't mind going to a person's garage if they know what they are doing and have the tools do it all. Familiarity with s2ks is obviously a bonusand im willing to drive quite a bit. Even in the chicago area is doable if they don't charge more than they should
Pic of car for those who didn't go to the MSU show :^)
I emailed Horsepower Techs, Boost Controlled Performance, Jurgen's, i don't even know if Jurgens would do a turbo kit, and i know horsepower techs is a little pricey.
Open to all options, i dont mind asking around. I actually also prefer like a small private owned garage/shop where i can help/watch/ keep company
If someone wants to tackle this in their garage, thatd be pretty sweet too
Kit installed by a friend at a shop over the course of 3 full days. Only slept once and helped the whole time
I went to chris to have him lean out the AFR readings on the emanage. it will suffice until i can get an standalone ECU and then im going back to him. Awesome guy.
@Chris's
@Chris's
chilenny
11-19-2009 06:23 PM
