Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
Is this normal?
Old Jul 11, 2009 | 05:45 AM
Sub_01's Avatar
Default Is this normal?
I have 02 s2000 and I have this idle issue I am not sure if its normal or not.
When I rev it up to like 2000 in neutral when the idle drops, it drops really low the car makes vibration sometimes almost like it was going to die. I found it more noticable in the morning right after the car warms up. I replaced map sensor thinking it might have something to do with it but still seems the same.
Can you help me figur this one out? Thanks .
Old Jul 11, 2009 | 07:28 AM
jeggy's Avatar
normal. it might even stall when theres a big temperature change when you last drove the car.
it's the ECU learning it's idle setting.
Old Jul 11, 2009 | 10:10 AM
Luder94's Avatar
Sounds like a DIY....it's called a MAP WHACK. No, seriously.
https://www.s2ki.com/search/forums?query=map+whack
Old Jul 11, 2009 | 10:54 AM
Ness2000's Avatar
And clean the idle air control valve. It's also in the DIY/FAQ. If you're in Indiana I'll do it for you if you bring it over
J_s2
Jul 29, 2019 06:13 AM
abarca54
May 1, 2014 12:10 PM
adz9
Mar 8, 2010 09:39 AM
UniqueS2k
Nov 16, 2006 06:21 AM
iwantyellows2k
Feb 17, 2004 02:52 PM
