Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
Problem with my car question on window/top
Old Oct 27, 2004 | 08:13 PM
Dezoris's Avatar
Default Problem with my car question on window/top
The car is under warranty, the search function on this site is so aweful, I would rather eat my own fecal matter than try to find what I am looking for.
This may be a common issue, so please let me know.
I went to put the fuc*king top up today, and the drivers side window would only go down like 2 inches and the stop.
Window works very nicely, no problems.
Just when I try to raise and lower the top the drivers side window barely goes down.
Whats the diagnosis, besides, that I am gay for owning an s2000 and also attempting at driving with the top down at all.
Old Oct 27, 2004 | 08:26 PM
shift_9k's Avatar
That used to happen to me, then just kinda went away itself.
I know that doesnt help but your not alone.
Old Oct 27, 2004 | 08:42 PM
Luder94's Avatar
Window regulator issue. It's well documented in the UTH forums....but like you said, the search feature may not be all that it is cracked up to be.
The dealership will just replace the regulator. I've had this procedure done 5 time already. 3 times on the passenger window and twice on the driver side.
Old Oct 27, 2004 | 09:34 PM
Johnny--2K's Avatar
Happend to mine once too...
Old Oct 28, 2004 | 09:32 AM
Dezoris's Avatar
Wheres the regulator?
Sounds pretty stupid.
Old Oct 28, 2004 | 10:14 AM
GChambers's Avatar
Banned
Mine is the same. I have just learned to live with it.
Old Oct 28, 2004 | 10:31 AM
ruexp67's Avatar
Inside the door
Old Nov 3, 2004 | 01:07 PM
hondamanwill's Avatar
I'm @ Darrow Honda and we had one that we found the controller for the top was bad causing the window not to go down.????? see your dealer to get it warranted
Old Nov 3, 2004 | 03:53 PM
SwansS2K's Avatar
Possible temp fix.......
Turn the car on
Push the window button down until the window is all the way down
Continue to hold the button down for an extra 10 seconds
Then pull up on the button and have the window come all the way up
Continue to hold the button up for an extra 10 seconds then let go
Turn car off and then turn back on
This resets the regulator. Sometimes works. I was out of warranty and this has worked on mine.
Just my $.02
Old Nov 4, 2004 | 09:45 AM
Dezoris's Avatar
thanks
