Replacement for s2000
Thanks!
and thanks for the license plate ideas urmil. I like ltwght.... when i used to workout that was my saying (if you have not seen any ronnie coleman videos on youtube - check them out you will get a kick)
Starting ripping everything apart this weekend. The widenand and V1 were not hardwired, so that needed to get done.
I also had oil temp and pressure gauges laying around, so I will be installing them too. Oh and While I was at it I also ran 12 extra wires from the front to the rear of the car. I don't want to go through that again.
I will also be plasti dipping the speakers as they are silver and reflect a LOT off the windshield. Quite Distracting.
Last, I will be installing LED lights in the footwells as courtesy lights, and adding a 15 second delay switch to the interior lighting. The lotus isn't very friendly on ingress/egress and the current lighting is laughable.
Top off
[attachment=34758:ImageUploadedByTapatalk 21361757331.507884.jpg]
Seat and stuff removed
[attachment=34760:ImageUploadedByTapatalk 21361757390.698128.jpg]
2 harnesses and 12 wires ran
[attachment=34761:ImageUploadedByTapatalk 21361757459.499292.jpg]
Plasti dip 1 coat
[attachment=34762:ImageUploadedByTapatalk 21361757484.957176.jpg]
Top off
Plasti dip 1 coat
Thank you sir, I have some parts still en route to finish it up, so I am not sure when help will be needed or when I will get to finish. But at the very least you can be go for a test ride with me to make sure I didn't mess anything up too bad.
From: The land of corruption, cachaça, and caipirinhas.
