Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
spark plugs
Old Jul 6, 2005 | 11:39 AM
s2k_suprchrgd's Avatar
Angry spark plugs
hey guys, i would like to know what are the best spark plugs for my supercharged s2000 and where exactly i can buy them at? my check engine light is on, so i went autozone and they said that its miss firing in each cylnder, should just change my spark plugs or is there anything else that might need to be changed?
Old Jul 6, 2005 | 03:09 PM
VAD's Avatar
VAD
I'd be inclined to use the O.E. plug. It's a relatively cold plug, which is proper for a s/c application. The NGK is a PFR7G11-S, or stock number 7772. Where are you located? These plugs retail at $29/ea. We sell them normally at $13 ea. I could get them at $9.90 ea. If you're close by, we could meet up and I'll hook you up. If you're in the Chicago area, I'll be at the unofficial meet tomorrow. Let me know soon if you want to do this!
Good luck! -Dave.
Old Jul 6, 2005 | 04:58 PM
Dezoris's Avatar
Farm and Fleet or any NGK dealer. DO NOT put any other plug other than than the OE, or the Iridium version.
Old Jul 6, 2005 | 05:26 PM
blackfx35's Avatar
I'm planning on getting denso IK24 (1 step colder) for my sc application. Check out http://www.sparkplugs.com
Old Jul 7, 2005 | 08:31 AM
VAD's Avatar
VAD
Denso's=
Old Jul 7, 2005 | 10:52 AM
VAD's Avatar
VAD
Harry, if I'm not mistaken, Autozone just plugs in an OBD-II scanner to diagnose. I don't think they'll actually pull the plugs out and "read" them.
Old Jul 7, 2005 | 12:58 PM
they just scanned my car then told me that it was misfiring in each cylinder and that i need to change my plugs. what about using ngk plugs(pfr7g11s) i heard those are really good? which one sould i go with DENSO OR NGK? IF NGK ARE BETTER THAN VAD CAN U PLZ GET THEM FOR ASAP. THANKS NICK
Old Jul 7, 2005 | 01:04 PM
VAD's Avatar
VAD
It's probably best to pull them and read them, as Harry suggested. It may be better to go with a colder plug, being that you're s/c. How many miles on them with the blower?
Old Jul 7, 2005 | 02:22 PM
i think i have 4 to 5k on the plugs. where do i take the plugs so i can read them? i just pulled my plugs they are fried. i had NGk v-power in there. one plug is missing the end of the tip from the plug how do i get the metal tip out should i just a slim magnaget or is there any other way?
Old Jul 8, 2005 | 09:53 PM
Dezoris's Avatar
Originally Posted by hecash,Jul 7 2005, 01:58 PM
As long as you are using a "top of the line" item, both are worthy manufacturers. So, whether it's NKG or Denso is not material to the issue. The heat rating of the plug is material. You can read the plug and make a judgement as is mentioned in the post above.
Sorry I took for granted he was supercharged.
I said NGK, because after owning 5 Hondas, and seeing other Hondas, in NA engines NGK seems to be the least problematic and longest lasting plug for these engines.
Harry is right though you pick up the top grade, densos, or NGKs in the right heat range you will be golden.
