Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
Trunk lid lock question
Old Feb 4, 2010 | 04:38 PM
sam_spider's Avatar
Site Moderator
Community Influencer
Default Trunk lid lock question
Okay, so I bought a new (used) trunk to mount my new wing to and the seller included all the OEM parts on the trunk lid.
So, my question is will my keyless fob unlock the new trunk (I didn't get a key for it) since it has all the hardware on it, or will it not work since my keyless system is for my car. I only have the factory keyless system, not an alarm.
I'm guessing the trunk release inside the secret compartment will also work (I hope) with the new trunk, but I don't know if the key fob will work as well.
I will be swapping trunks off & on for track days, so I'll need the hardware to stay on each trunk as is. So, I'll have 2 trunks that need to be functional.
Any ideas? Any help is greatly appreciated.
Old Feb 4, 2010 | 05:13 PM
laurensdejong's Avatar
The remote unlock (both fob and trunk release button) sends a signal to the trunk lock cylinder, so all you have to do is unclip the wire that runs through the trunk, yank out the trunk, replace it with the new one, push-pull the wire through the new trunk, clip everythin in place again, and (hey presto), you're good to go.
I tried, and it didn't seem too hard. The wire part, that is. I didn't physically remove the trunk
Old Feb 4, 2010 | 05:14 PM
boostseekings2000's Avatar
if you already have it insert the key and turn it see if it rotates...the button will work as long as everything is connected the right way but i highly doubt the key will work
Old Feb 4, 2010 | 05:16 PM
Brilliancehondamike's Avatar
no, you need the key for that trunk because you cant rekey the new honda sidewinder keys. so if you wanted youe key you have now to work in it you would have to switch out the lock out.
Old Feb 4, 2010 | 05:23 PM
sam_spider's Avatar
Site Moderator
I'm not worried about the key working at all, I'm only concerned if the key fob and trunk release inside the car will work.
Old Feb 4, 2010 | 05:25 PM
sam_spider's Avatar
Site Moderator
Ah, gotcha. Thanks Laurens
I couldn't remember how many wires go to the trunk. I know of the one for the 3rd brake light, but mine isn't connected, so I wasn't sure how the rest worked.
Old Feb 5, 2010 | 03:31 AM
Kamron's Avatar
Sam, you could always swap the lock cylinder also, it looks like it's pretty easy to do from my factory service manual. (Like 2 bolts).
I would do that as a precautionary measure in case of some electrical component failure. That way you're not stuck trying to get the trunk off and possibly damaging it.
Old Feb 5, 2010 | 02:35 PM
midwesta's Avatar
Everything will work fine, minus physically using the key.
Old Feb 5, 2010 | 04:13 PM
sam_spider's Avatar
Site Moderator
^ Promise??
I appreciate all the help, thanks guys
Old Feb 6, 2010 | 02:21 PM
then yea the fod will work jsut fine miss read up top
