Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
lowering springs
Old Jan 5, 2010 | 07:26 PM
chad86's Avatar
Default lowering springs
Well i was installing my rims today and I noticed that after they were mounted that there is a fairly big difference between the driver and passenger sides.
there is:
almost 2 finger gap on the driver side rear
and 1 finger gap on the passenger rear
both front and back are like this.. except front driver has 1 and a bit finger gap and passenger has almost no room.. kinda hard to explain.. I could try and post pictures if it would help
I did not d the install of the springs.. It cme with the H&R springs installed.. Do you think they could have put two rears on one side or something.. Has anyone ever heard of this... I know i would be better off with some coilovers but not sure if i can afford it right now..
thanks guys
Old Jan 5, 2010 | 08:32 PM
Chow-bot's Avatar
did you have any difference in height with the old rims?
Old Jan 5, 2010 | 08:36 PM
ss04's Avatar
Sell me your rims so you can afford coilovers
Springs will never be a perfect even drop. Weight is not distributed evenly among all four corners of a car, and your front 2 springs and rear 2 springs are going to be identical. Hence the difference.
Sounds more substantial in your case though
Old Jan 5, 2010 | 08:37 PM
ss04's Avatar
Also make sure you go drive your car around again. When you drop your car back down onto the ground it never settles evenly.
Old Jan 5, 2010 | 08:46 PM
chad86's Avatar
tahst what i was thinkin.. i saw that the sides were a little different with the other rims, and i did a preload on the higher side to see if i could lower but i didn't help much if anything... i am thinking that because of the higher offsets it may make it a little more noticeable.. i can't take it out for a drive for a while because of the snow, but i will let it settle for a couple days and see if it gets any better anyone know of any good coils for sale mfor a decent price
Old Jan 5, 2010 | 09:48 PM
rk604's Avatar
If for example:
Front (Left) = 2finger gap_________________Front(Right) = 1finger gap
Rear(Left) = 2finger gap__________________Rear(Right) = 1finger gap
maybe whoever installed your springs got one of the springs mixed up, as in, put the rears to the front and front to the rears. Or vice versa. I know there was a problem for those who installed skunk2 springs, some of them wanted the "rake" drop, so they put the rear springs to the front so it gave them a better look (rear springs drop more than the front) or the "rake" drop that was intended.
Old Jan 6, 2010 | 03:09 PM
chad86's Avatar
yah u got it... but what you said would not account for the sides being different right... if they were just swapped out then the balance from the back and front would be off but the sides are different right. so it would be almost like they put the rears on one side and the fronts on the other.. i will have to check that in the spring.. they have stteled down a little more tho.. so i may have just got over excited/worried about it... i may look into some megan racing colovers some time soon though.. they seem decentlly priced and i have read some good things on them.. much lower and i will need some bigtime fender rolling and move the biumper bolt
Old Jan 6, 2010 | 08:27 PM
rk604's Avatar
well, what i assume might happen is, they put the front springs on the driver side, and the rear springs on the passenger. Which would explain why one side is higher/lower than the other. IF your springs aren't that old, you can always look at the serial/product code to see if they are switched around as we thought
Old Jan 6, 2010 | 08:43 PM
chad86's Avatar
yah i will take the wheels off and see if i can see anything to check if they are correct... i hope they didn't install them wrong and i have been driving for like 3 summer with them this way
D Loke
Oct 20, 2008 09:35 PM
johnqt3
Apr 23, 2007 07:49 PM
Formula
Aug 16, 2004 06:25 PM
kevsS2
Nov 30, 2003 07:40 PM
DJHohum
Dec 19, 2001 02:36 PM
