Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
Newbie Question
Old Feb 17, 2009 | 07:12 PM
DDonovan's Avatar
Default Newbie Question
When I was at the meet in November I noticed a couple of cars that had a filter off of the valve cover. The first hose from the front of the car and it seemed to go to the intake hose, was removed and a small K&N filter was on the cover...,
If you know what I am talking about what is that called and what are the advantages?
Thanks.
Old Feb 17, 2009 | 09:52 PM
alSpeed2k's Avatar
Maybe you should go through the pictures and post it here.
Old Feb 17, 2009 | 10:01 PM
Hakkaboy's Avatar
it's called a breather filter.
http://www.cimotorsports.net/motor-sport-p...her-filter.html
Old Feb 17, 2009 | 10:10 PM
DDonovan's Avatar
I think that is it..., here is one installed on an engine. See the small filter on top of the valve cover ..., What is the purpose and advantage of this?
Old Feb 17, 2009 | 10:20 PM
DDonovan's Avatar
OK checked it out..., sounds like a good idea for FI but not for NA and there really are no gains except slightly cooler air for the intake as the air ported through the existing hose is heated.
Old Feb 17, 2009 | 10:41 PM
S2S's Avatar
S2S
on FI you have to run that breather otherwise the charger will pressurize your crankcase. BIG NONO. as for NA the air flow is going towards the engine because its being sucked into the intake manifold at a different location via the PCV valve (positive crankcase ventilation) so it offers no gains NA or FI. the reason it goes through the air cleaner assembly is because its filtered and i hope i dont need to explain why you crankcase needs to be filtered. hence the mini filter.
in case anyone is wondering what the PCV system does, it removes unwanted and harmful gases from the crankcase. (crankcase = inside your motor not including the combustion chamber)
Old Feb 18, 2009 | 08:50 AM
DDonovan's Avatar
Thanks S2S.
Old Feb 18, 2009 | 10:29 AM
Vik2000's Avatar
It sure looks cute though. I think I can hang it on my keyholder.
Old Feb 18, 2009 | 12:15 PM
S2S's Avatar
S2S
your welcome. ill be here all week!
Old Feb 18, 2009 | 06:40 PM
Koski's Avatar
haha do it
