Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
OBDII Scanner?
Old Nov 3, 2009 | 06:44 PM
legin_k's Avatar
Thumbs down OBDII Scanner?
looks like i need to aircare my car before saturday.. when i first got the car, two of the vacuum hoses were connected incorrectly, so it was giving me secondary air pump malfunction code. i reset the ecu, but haven't actually cleared the codes yet.
soo, does anyone have an OBDII scanner that i could clear the code with?
perhaps someone could bring one to the meet/cruise this thursday?
Old Nov 3, 2009 | 07:33 PM
turbo_slug's Avatar
I have a scanner but I'm pretty sure clearing the code won't help because you would have cleared it when you pulled the battery.
Old Nov 3, 2009 | 07:44 PM
wowowox's Avatar
Agree !
Old Nov 3, 2009 | 08:19 PM
legin_k's Avatar
oh, so the code won't be a problem if the battery has been pulled? i was under the impression that the stored code would still show up?
Old Nov 4, 2009 | 02:31 PM
legin_k's Avatar
can anyone confirm that you can pass aircare if you've pulled the battery to clear the cel, but haven't cleared the saved code with a scanner?
Old Nov 4, 2009 | 02:33 PM
s2000_vtec_mike's Avatar
Yes i had to clear cel lights in my s4 all the time to pass aircare. Right befor i go in, and as soon as i got out i the cels came back on. So good luck
Old Nov 4, 2009 | 03:42 PM
turbo_slug's Avatar
i assume you cleared the codes with a scanner. i'm surprised it didn't cause the car to go into the not-ready state (which would cause you to fail aircare).
anyways, i spoke to the OP and it sounds as if his CEL is no longer on. he just thought that the code would still be stored in the ecu even after he reset it.
Old Nov 4, 2009 | 03:49 PM
no i used a scanner haha theres a scanner in each of my cars haha.
Old Nov 4, 2009 | 09:59 PM
legin_k's Avatar
so.. cel not illuminated will pass air care, even if i fixed the problem but only cleared the cel by pulling the battery? (12 months ago)
Old Nov 4, 2009 | 10:26 PM
turbo_slug's Avatar
Yup you're fine
