Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
P0411 cel code help
Old Sep 25, 2010 | 10:24 AM
ChaseBaciles's Avatar
Default P0411 cel code help
Recently purchased 2001 s2000 has the cel code p0411. After heavy research, I understand it is due to secondary air injection system incorrect flow. Either leaks, cracks, kinks, backward white check valve, switched up hoses or cracked air pump.
Troubleshooting done. Checked hoses 5-6 times. No obvious cracks. Hoses are hooked up correctly. Found a sloughs crack to the hose under air pump. Repaired. Air pump in good shape, no cracks. Wiring all good, pump activates at start ups.
I am all out of idea here. Ecu has een reset. Code keeps coming. Back. What else am I missing. I also hear the slave open and close so I know that's working.
I've brought it in to a mechanic. He said that the valve could ve getting stuck sometimes and could maybe use cleaning. Any idea what he means and f I could do this myself. After all the reviews about this issue, it doesn't seem to be common the valve gets sticky. I know it's not a critical error but that damn cel light is bothering me.
Old Sep 25, 2010 | 04:58 PM
turbo_slug's Avatar
there's a control valve. it could have gone bad or your hoses are swapped around...
PM me if you need to buy a valve
Old Sep 25, 2010 | 06:22 PM
Thanks bro. Anyone have a pic of what this valve looks like. Possible to clean it? I looked at the hoses. Everythings tight. I've followed a few diagrams of the order. Unless you mean the wrong size hose has been used... Which I would be able to tell if it's wrong size or not.
Btw. Is the valve install if I go this route a diy?
Old Sep 26, 2010 | 12:03 AM
turbo_slug's Avatar
The valve looks kinda like an egr valve but s2k's don't have an egr valve
Old Sep 26, 2010 | 09:51 AM
thanks man, how much are you selling those valves?
ChaseBaciles
Aug 4, 2020 08:05 PM
FromaDB2toanAP1
Jan 21, 2014 04:30 PM
attack666
Nov 11, 2007 06:23 AM
simon122
Mar 12, 2007 11:28 AM
ken-e
Jul 20, 2005 09:22 PM
