Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
Tire sizing
Old May 25, 2009 | 05:17 PM
dogzilla's Avatar
Default Tire sizing
Hi guys, I am looking to buy a set of Dunlop Direzza Sport Z1 Star Spec, and I am wondering what size do u guys use. I would like to mainten the stock stagger ratio, so I was thinking to go with 215 front and 255 rear, I was also thinking to buy a set of RPF1 in 17x7.5 +48 17X9 +45, would I run into any rubbing issues? Thanks in advance.
Old May 25, 2009 | 05:20 PM
ronac's Avatar
Where are you thinking of picking them up?
I've been thinking of either getting a set of Star Specs or the new Kumho XS. I'm probably going to go with 225 F and 255 R.
Old May 25, 2009 | 05:29 PM
dogzilla's Avatar
it depends, if I can find someone to buy my stock ones from seattle, I will drive down to discount tire in bellingham, and buy a set of enkei rpf1 and the star specs from them. If not, I will probably have the shops ship the tires to point roberts, and pick them up from there.
Old May 25, 2009 | 05:47 PM
mavm86's Avatar
Go with 225/255. 215/255 will understeer too much. The star specs are a good choice from what I've heard.
Old May 25, 2009 | 05:48 PM
JL9000's Avatar
The fronts will be okay for the RPFs but rears will rub for sure if you're lowered. You should go a little wider in the front if you plan to run 255s in the back.
Old May 25, 2009 | 06:23 PM
dogzilla's Avatar
so 225 front will not rub at all? so how do I fix the rubbing issue with the rear if I am lowered? roll the fenders?
Old May 25, 2009 | 06:56 PM
undeRwhelmed's Avatar
I'm running 225/255 RE01-R's and found there to still be more understeer than i'd like on tighter to medium corners. I'd definately stay away from 215's up front if you are gonna use 255's out back.
Old May 26, 2009 | 07:18 AM
viNz86's Avatar
Yah, roll fender and camber. Should be fine with that setup.
Old May 26, 2009 | 08:59 AM
kfdon's Avatar
depending how low you are you might need to relocate the rear bumper tab.
i recall your in BSP in autoX. and if your planning to change calipers later on RPF1 will not clear the calipers.
i tried the z1 on owens car ( THX!! ) pretty good
but i got a set of XS for myself , just to test it out and it was cheap
Old May 26, 2009 | 12:10 PM
Chow-bot's Avatar
I have the same spec of rpf1's
you will rub no matter what the second you lower it with out a roll and camber.. I will post of a pic of my rears later today to show you.
panamaem1
Jan 19, 2012 04:11 PM
B serious
Apr 14, 2010 09:35 PM
iziegsx
Mar 6, 2009 04:38 AM
LegendaryHarry
May 2, 2008 12:32 PM
LAKERFAN1975
Jul 31, 2006 07:13 AM
