16's, 17's set up tips?
nope. i am running this with oem nsx wheels.
most likely you will want 205/55/16, or 225/50/16 tires in the front,
and either 245/40/17 rear, or 255/40/17.
finding tires that come in both sizes is a little more of a challenge, but there are still several of options.
not sure of any benefit to this. if i was buying volks or something else, work, enkei, etc.. id get 17/17.
which wheels are you looking at?
you want to keep the total diamater as close to stock as possible. otherwise ABS on the front will fawk up, and the speedo in the rear will be off.
so if you change your rim size, you change your tire size in the other direction to compensate.
bigger wheel, smaller tire.
smaller wheel, bigger tire.
15/18 would be just retarded, but in theory you can do it. youd be running a 30-35 profile tire in the rear, and probably a 60-65 sidewall in the front.
(not exactly maybe, but close. id never run a 15 or an 18 on an S).
