Need help with tires, 17" wheels
I am thinking about S-03, 205/50/17 front and 245/40/17 rear, on some 17" wheels. Does that make the car less oversteer? I wanna make it less oversteer.
Tread width front = 7.6" , rear = 9"
VS
Stock tread width front = 7.1" , rear = 8.5"
What do you guys think? Should I use 215/45/17 (tread width 8") front instead? Also, does the Rim width affect the tread width, even with the same tire? For example, 245/40/17 on a 9" rim, would the tread width be wider than the same 245/40/17 on a 8" rim?
Thanks.
VS
Thanks.
If you push the car hard to get to its limits or auto-x your car the S-03's SUCK! Keep in mind that the compounds for the rubber are WAY different and the S-03's have very wide grooves for water. I have 215/17 and 245/17 and car handled nicely. I could drift the car easily around corners but well............drifting limits were way lower IMO.
Once I hit the auto-x or track with them the first lap was the fastest and held the best...........after that they got to hot and slid.
Spring time I am looking at getting the OEM S-02's for either the Boxster or the 911. Sizes 205/17 and 255/17!
Can't wait!!!!!
Can't wait!!!!!
[QUOTE]Originally posted by Carlson
[B]
So if I use 215/45/17 and 245/40/17, my car will oversteer more than yours/ or stock S2K?
I really want it to oversteer less, but I am afraid 255/40/17 would slow the car down a bit.
[B]
